My issue is the front main seal, not the rear. So you're suggesting that chances are my steering pump and rack and pinion are likely not the problem, and it is probably just a hose or boot problem? The layout of the VG is pretty intimidating, and the lack of room in the bay doesn't help that. Hopefully you are correct and once I start to learn my way around her it'll become as simple as my SR was. Thanks for all the advice
